-   -   Trivia (https://www.racingjunk.com/forums/showthread.php?t=26986)
Harbone 01-15-2010 05:40 PM
:D
now I am trying to multi-task, eat dinner, sip a cold one, run my mouse, look at 3 different forums and type...GEEEZ!!!!
easy one, how many Camaro were made in 1969 with the nasty ZL-1 option :?:
dragonmaster093 01-15-2010 05:45 PM
69
Harbone 01-15-2010 05:48 PM
Originally Posted by dragonmaster093
69
again WINNER WINNER CHICKEN DINNER!!!
dragonmaster093 01-15-2010 05:59 PM
name a gm none chevy aluminum engine in the early 60's
Harbone 01-15-2010 06:07 PM
rover, 215 inch V-8?
fla1976 01-15-2010 06:09 PM
Olds, Buick and Pontiac 215 V8. Also used in Triumph TR8.
BEAST477 01-15-2010 06:09 PM
I believe it was a Buick. Not sure of cid.
dragonmaster093 01-15-2010 06:12 PM
hmm all right
The GM 215 cubic inch aluminum V8 engine (and its Rover descendants) have historically been the V8 of choice for MG conversions because of its light weight and compact dimensions. The engine was domestically available in a variety of 1961 to 1963 Buicks, Oldsmobiles, and Pontiacs and in several performance levels.
Stock horsepower ranged from the standard Buick Special's 155 H.P. / 210 lbs torque to the Oldsmobile Jetfire's turbocharged and fluid injected 215 H.P. / 300 lbs torque. Of course, the most desirable aluminum V8's are the higher performance versions with increased compression ratios and four barrel carburetors. [Editor's note: if you're going to rebuild a Buick 215 anyway, you can easily change compression ratio by selecting different pistons. To change compression ratio on an Olds 215, you're probably looking at swapping heads. That's another article. Buick and Olds 215's have entirely different valve covers, which is probably the quickest way to sort a stack of them. Heads and valve-train are what really make Buick and Oldsmobile 215's quite different, but that's another article too!]
guess you have fight for who goes next
Harbone 01-15-2010 06:15 PM
someone else take it, I am starting to run out of questions I actually know and will have to start breakin out the reference material :!:
fla1976 01-15-2010 06:18 PM
Ford
Who supplied the engines for Henry Fords first Autos?
