billhendren wrote:
The Jesel or C.V. products belt drives will run for several thousand race miles without a belt change and are the best choice if the budget allows. Bill A CompCams rep told a friend that he should replace his belt every year, but that seems a bit excessive. His belt had broken on his SBC 429 after about 3 years and the spider gear was well worn, so he is now wanting to change every year. Thanks for your inputs, Bill M |
Look at it this way, the Nextel cup guys run them for 500 miles at a time with no problems.we run them at least that far on our super late models and have never had a broken belt.some of the early belts were only 20mm and we did see a few failures but after they went to a 25mm belt we haven't seen any breakage.Bill
Bill, thanks again for the advice. That was along the lines that I was thinking (at least 500miles).
Bill M |
Sorry guy I don't get to this forum often enough.
A chain or belt is the way to go. For the money a good chain is hard to beat. If the budget allows I like the CV Products Belt drive. |
| All times are GMT -8. The time now is 09:00 PM. |
