Originally Posted by bjuice
its killing my little raggy 511...lol :D
George |
sucker-suck-a- tash,,you rat fink......lol
Originally Posted by davis419b
David, Why are you adding a 100lbs to the car.
Shucks, there goes a .010 right there in weight and a .010 in suspension !
...getting a little over 1,000 hp on his 565ci with the new oval port heads...
Decisions, decisions. George |
This is 2nd time I've done the switch first time I lost .10 with weight and suspension both. I have a few other things to get it faster, changing from the 34.5's back to the 33.5 hoosiers .04 there, conv is stupid loose because the car wouldnt go straight/hook at any track. 6800 stall falls back to 6200 and sits there for .50-52 seconds after shift, I have a 6200 TSI 9" spragless to put in it. It went 4.67@147 in 3200ft of air and 91 degrees. Could be the most tire shaking/spinning car I've ever drove, hope the suspensions take care of this issue which I am sure it will. I'd like to settle it back in around 4.75@145
Decisions, decisions. George my cousin purchased the PAR 565 and ran it in a 3000lb 67 nova with driver and ran consistant 5.60's with a low et of 5.58..on gas and all motor. ladder bar ,small tire car.. if somehting happend to my 511 i hope it happens early next year cause i will go with a 565 shortblock and use my conventional heads..on alcohol of course..lol So yes i say 565ci with conventional heads for sure ! Brian |
The only way i could get rid of tire shake with the new car is the 34.5 tires . Get a Hughes 9" softhit conv. It hooks consistantly and picked me up 4 hundreds over the loose GM-95
Decisions, decisions. George my cousin purchased the PAR 565 and ran it in a 3000lb 67 nova with driver and ran consistant 5.60's with a low et of 5.58..on gas and all motor. ladder bar ,small tire car.. if somehting happend to my 511 i hope it happens early next year cause i will go with a 565 shortblock and use my conventional heads..on alcohol of course..lol So yes i say 565ci with conventional heads for sure ! Brian the 565's run good, but almost every 582 around here out runs the 565's by a good tenth. I've seen APD put a 1950lb american with, oval port bb3x's go 7.21 . Davis I think the 4 link will help this I have a set of 34.5's just in case not. Its hard to make a 225" Car made for a small block hook on a hot track with the big block. It sure was ill to drive. |
The Coan 6800 is a softhit also, I have a few conv's sitting on the shelf to try good thing for early spring testing :D |
| All times are GMT -8. The time now is 07:26 AM. |
