-   -   bad water pump? (https://www.racingjunk.com/forums/showthread.php?t=20312)
suicidebomb 03-22-2008 10:46 AM
Originally Posted by Stappy
I believe you have a flux capacitor problem......it's what
makes time travel possible.
Could be, I was forced to give up time travel when I gave up hard narcotics!
suicidebomb 03-22-2008 11:06 AM
Originally Posted by lively
I HAD TO PUT 125 POUNDS OF HELIUM IN MY DRIVESHAFT TO KEEP MY SBF RUNNING COOL[ WITHOUT THE COMP VALVE HOOKED UP :cry: :cry: ]
Whatever you do, don*t put helium in your third member..... you*ll HAVE TO run wheel weights!
johnracer 03-22-2008 11:14 AM
Re: re; bad water pump
Originally Posted by suicidebomb
THATS RIGHT!!! we had a bad kanooter once that caused us to have to use a rather unorthodox fuel... Coleman fluid, we set our total timing to 13*. We burned up the upper drive flange, dumba$$ us we forgot to chamfer on the block side! Tee Hee we*ll never do that again!!!
Also, when using Coleman fluid, a little KY on the spark plug ground straps helps prevent premature "burnoff".
suicidebomb 03-22-2008 11:42 AM
So, I suppose you guys are OUTSIDE working on your cars today?
johnracer 03-22-2008 11:48 AM
Of course, but a guys gotta eat and or take a leak once and awhile. So why not offer up some good advice while you're in the house. Right?
ojpearce05 03-22-2008 03:47 PM
I had the same problem, it was the blinker fluid and muffler bearings at the same time. Never knew both could got out all at once. :lol:
Racefab57 03-22-2008 05:34 PM
What the HELL is this thread about??????????????????????????????
Tod74 03-22-2008 05:40 PM
hahahahaha
Stappy 03-22-2008 06:03 PM
Troubleshooting......??
lively 03-22-2008 06:50 PM
A BAD WATERPUMP~~~~~~~~~~~~~!!!!!!!!!!!!!! :lol: :lol: :lol: :lol: ---ALWAYS USE TEFLON TAPE ON THE MUFFLER BEARINGS :shock: :shock: :shock: THAT KEEPS THEM FROM LEAKING OIL ON THE EXHAUST :cry: :cry:
