-   -   Chevelle Frame Question (https://www.racingjunk.com/forums/showthread.php?t=20542)
blue66 05-25-2008 04:05 AM
This has nothing to do with boxing the frame.....which I wouldn't bother with anway but, have you done some research on the extensive modifications needed to install a 632 in you car?
The fronnt crossmember needs to be notched for pan clearance because of the stroke. And Steering modifications or switching to a rack setup will be needed to clear the pan also.
Also plan on spending at least 1200-1500 for headers to fit in the car.
Just wanted to give you a heads up if you haven't researched it too much.
