-   -   oil pump problem (https://www.racingjunk.com/forums/showthread.php?t=21108)
jmarksdragster 06-20-2008 05:34 PM
Originally Posted by alexu
Found out melling had redesigned m55 per gm to save weight. Don't know why. Melling's m55hv has not been redesigned and it works great. Dirt track customers have had the same breakage problem.
M55HV is no longer an option. The 10555 is a better casting, but uses powdered metal gears. Use at your own risk. :roll:
alexu 06-21-2008 10:31 AM
oil pump problem
Hate to here that . I'll need to inform my dirt track, street and drag race customers that their pumps that are running great need to be replaced.
jmarksdragster 06-21-2008 10:53 AM
If the pump is more than roughly 2 years or older, you are OK. All the newer stuff is PM. I e-mailed Melling last year and they confirmed this. They also supply Moroso, Milodon, and a few others with gears.
