I have used a small bolt and some black silicon for this
The plugs that go around the cam fit.
I have a dipstick tube that I welded a strap to to bolt it in the block right below the dipstick. You could do the same and add some silicone to it before you slide it in..should fix the issue. I was using a chrome dipstick too. I can probably post a picture sometime if needed..
Originally Posted by ARUSSELL
Pull out the dipstick and put a freezeplug in the hole. I have a site pulg in the side of my oil pan and with this setup no leaks!!!!!
| All times are GMT -8. The time now is 09:01 PM. |
