i broke a rocker stud twice b4 i bought mine but it had 3/8studs
510hyd |
I broke a rocker stud in my 572ci Camaro. If it hadn't been for the girdle it would have gotten ugly real quick.
Don't leave home without them!
Originally Posted by dparker
Sunset Racecraft racing engines does not run them and has great luck. Last year at Indy it was said that 75% of the sportsman class had Sunset Racecraft engines. There reasoning is that when you put a stud girdle on it pulls some of the rocker studs to where some are in a bind causing them to fatigue and later brake. Its is true you have a extra lock, but you also have to loosen an extra thing to adjust. But on the contrary, Reher Morrison builds a great engine and uses stud girdles. I believe there reasoning is that it takes the harmonics out of the valve trane that causes fatigue. I have one of each and both are great engines. I've not had to readjust either.
| All times are GMT -8. The time now is 08:18 AM. |
