I was told to use laundry liquid softner
I have been told it takes the air bubbles out of the system and laundry liquid softner does the same thing?
Well, I tried it in a 2-stroke (KX250) that was getting hot on a 33mi annual poker run I used to do. The year I tried it (2003) it made a difference. All I know is that it did not over flow like w/o the water-wetter. In a race car, I do not have the expierence though. Scooter
not allowed on the track here, blow a hose or freeze plug going down the track and its slipsville...
I bought into the anti corrosion and water pump lubrication properties as well.
I run distilled water and water wetter. Don't know if it runs any cooler. |
I run it in everything I own. Does it work? hmmmmm... I really dont' know. I guess I got it just in case it does. :oops:
All kidding aside we use to put it in warehouse forklifts that were running hot. It did cool them down and good bit. Probably 10-15* like other guys said. |
I found Purple Ice from Roaya Purple works better
DOESENT DISH SOAP HAVE FOAMING AGENTS??? :shock: JUST A THOUGHT?!
water wetter
I used "Below 40" in my mini sprints and full sprint car. Never ran a fan on the radiator, only air flow is when we were moving. Liked the way it ran the temp down. Worked quite a bit better than the "WATER WETTER". You run it with distilled water and a slight amount of anti-freeze.
It does not work if you are making any power with a non adaquate cooling system, Dont waste your money, fix the problem
| All times are GMT -8. The time now is 09:44 PM. |
