we are using arp head bolts no studs and we used sealer on all the bolts thanks
Re: water coming out of head between header and head ???
Originally Posted by gpracer
please help we have brand new motor and we got it fired up and we have water coming out between header and head on # 4 and 6 cylinder what is causing this we took it apart had everything checked and put back together and same thing happened again ???? what is causing this ty for any help
Curtis |
we found the problem cracked cylinder wall taking back to machine shop thanks for all your help
Glad you posted back and let us know what you found. Sorry you had the problem.
Curtis |
WHAT A ROTTEN ENDING :cry:
Had that happen to a family member. Machine shop sleeved it and once he tightened the head down it cracked again. But his was getting water in the oil.
Gpracer, in using that 400 block your problem maybe the same again shortly. The 400 block is notorious for cracking the cylinders. The cylinders are simese and kinda thin. My advice if your running very much compression would be to invest in a dart block. Problem solved no more worries. Just a thought.
| All times are GMT -8. The time now is 11:07 AM. |
