-   -   what are best plugs to use?????????? (https://www.racingjunk.com/forums/showthread.php?t=24749)
cepx111 06-30-2009 10:04 PM
Originally Posted by montecarlo84
Autolite made in the USA
Good point, my next set are going to be autolights.
Cp
hammertime 07-01-2009 04:42 AM
I did a test a few years back autolites, ngk's, accel, champions
On my 548/alky carb the ngk's were flat SLOW compared to the others.
suicidebomb 07-01-2009 07:06 AM
Check this out, I got a set of brodix track 1s on my junk. They reccomend NGKs, so thats what I ran. then one day i decided to try a different plug, so i gets a set of autolites, supposed to be a direct replacement. I can screw the NGKs in by hand all the way to the gasket, the autolites would only screw in about two turns and stop, in every hole. The thread size, looks identical, but AINT. I'm not cross threading or anything else, they just won't screw in, and I aint going to push the issue. sure as the world if I do i'll strip those heads.
Scooterz 07-01-2009 11:06 AM
I don't care who you are... thats not a good story. Bad threads going into aluminum is like 3 peckered billy goat ina one-legged butt kickin' fight... somethin' bad is gonna happen.
