-   -   hp numbers? (https://www.racingjunk.com/forums/showthread.php?t=25383)
brett46 08-21-2009 02:05 PM
changes in mid stream
Ok change 1 to change 36. I picked up a set of dart pro 1 heads that have been ported. 2.08 in 1.60 exh 49 cc chambers which should put me around 12 to 1 with the flat tops. (not doing much street cruising,) that was the 3rd or 4th change anyway. I am needing cam recomendations...... around a 28-2900 lb truck, 383, dart pro 1 heads ported,1.6 rockers, springs are good for .550, but can be changed ,tunnel ram, twin 650s,3500 stall , Th 400 abruzzi trans reverse shift ,manual valve body trans brake , quartermaster ladderbar back half, narrowed 9 inch,w/4.62 or 4.56 wfull spool. Ok after listing all that, :roll: my question was what cam do you think?
engineaction 08-26-2009 08:55 AM
What type of cam are you thinking of running, Flat-tappet, roller, hyd or mechanical?
brett46 08-26-2009 02:26 PM
probably a flat tappet solid. Ive got a message into Lunati for a recommendation on a solid roller but havent heard anything back. It really depends on how much extra HP I can get with a roller, compared to a flat tappet If it is worth the $ for the roller than that will be it.
