Originally Posted by ss427nova
Wow, I called RPD one day with a dilemma over pin height for a super long rod on a long stroke crank. Jeff not only helped me by calculating the pin height I would need, he was doing on his luch hour and stopped eating long enough to help me out. I would still buy from him. Sorry you had trouble. Thanks to Jeff my 496 is thumping the ground. Now I just need to decide whether or not to junk the Pro Comp heads...... :roll:
I put a set of procomps on a sb for a friend who just wanted aluminum heads for a show car. I guess if that is what your looking to do there good for that :?
((( Uh OH....that is going to piss "gungho" off. ))) OOH CRAP HERE WE GO AGAIN,,,
I know, kinda like beating on the bees nest. I run dart , put the two next to each other the quality isn't even close. but hey each to there own. jmo
I may of been harder than I needed to be on the heads.Basically you get what you pay for.I have pulled 3 rockerstuds out of mine running a cam that is well in spec for the spring set.I couldnt imagine how much trouble you would have with these if you actually ran a roller cam with the roller springs..(Higher spring pressure).It takes some work to get the ports to match any intake and the geometry is not as good as it could be.They are what they are.A cheap knock off.People use them and there are those that have alot of luck with them.This is a perfect example of getting what you pay for.When I put this engine together I saw them and the price was so tempting I went for it.I only wish dart,brodix and afr would be alittle more competetive with their prices.Their quality could eliminate some of the knockoffs, its the price that keeps these things alive.Nobody in their right mind would pick the procomp over the dart if the price was anywhere close..Take care
We took the car out to the track today to shake it down. All I can say is P-I-G! I am seriously hoping it's not a few pulled studs, but there is a popping noise in the exhaust and it sounds like a flutter coming down the return road. Geez, my 427 would pee all over that 496!
| All times are GMT -8. The time now is 01:14 PM. |
