Originally Posted by Tod74
Why are you bothering with copper head gaskets on a low compression street truck for? :? I have ran fel pro 1017-1 with 14 to 1 compression.
Just use regular FEL PRO GASKETS and make your life much easier. jmo You can reuse the gasket providing to don't damage it when you remove it. Slack up on the silicone. Why are you putting it on your head gaskets anyway? Clean everything off really good and spray the copper gaskets with copper coat and install the gaskets, Its that easy.... |
Its not that easy. Pm Me if you want some help
| All times are GMT -8. The time now is 05:20 AM. |
