-   -   SBC AC oil filter collapsed (https://www.racingjunk.com/forums/showthread.php?t=26848)
krazy55ken 01-03-2010 07:51 AM
Its allways been k&n or wix for me,,
rob41willys 01-03-2010 08:36 AM
I use the wix racing filter
cartwright454 01-03-2010 08:39 AM
Originally Posted by TheEngineer
I think the key factor here, is that most of the race filters have a "much thicker" canister side wall thickness. Whereas, a standard filter (non-race) has a very thin canister. The internal filter element, is another issue.
Warren
The cansiter looked new. the filter element must have collapsed.
rob41willys 01-03-2010 08:46 AM
I always cut open the filters to see whats in them. you can catch a problem before it gets real bad. But I change them often though. You need to use a real filter cutter though so you don't have a bunch of metal filling from cutting it open
jaxsmith 01-04-2010 05:50 PM
Fram racing filters are nothing like their conventional filters. They don't pay me and there are other brands like NAPA and WIX "racing" filters that could be used. Bottom line is buy a heavy duty filter to match your engine. If your race engine does not turn more than 4500 rpm and has a standard oil pump you would never have a problem with a "standard" filter. My engines put out around twice the pressure of a stock engine and by the pump selection put out more volume than stock. I have never had a problem with a race filter. Go buy one of the good filters and cut it apart.
gnsrule 01-05-2010 01:47 AM
Originally Posted by cartwright454
So I will ditch the hastings and go with a wix. thanks
Nobody said anything bad about a Hastings.
Myself, I run a Baldwin. After seeing one cut open its a no brainer.
Craig
