-   -   Wiping a cam lobe (https://www.racingjunk.com/forums/showthread.php?t=27135)
kwkracing 01-28-2010 10:32 PM
Never had a cam issue, always run half rotella, half conventonial oil
Tod74 01-29-2010 12:13 AM
I have not used a flat tappet since around 1997...but when I used them in the past I never ever even allowed them to break in properly(fast idle 20 minutes) and I have never lost a lobe. I never used light springs either to break in...just used the ones for the cam I had.I always fired them up and held the rpm up just enough to keep it running a little fast until it warmed up enough to idle. Must be just lucky. Either that or it is the oil??? :?
mooneye777 01-31-2010 06:05 AM
I would not use anything othere then a roller set up now. It cost a lot more but its money well spent to keep that from happening.
Scooterz 01-31-2010 05:36 PM
Agreed. Nearest I can tell, this latest motor was a a crate motor w/ a flat tappet cam/pusrod slammer. Sad... it was fresh & he was all excited about driving the ol coupe.
murrayjest 08-25-2022 04:03 AM
