-   -   383? (https://www.racingjunk.com/forums/showthread.php?t=27470)
cncmotorsports 02-28-2010 05:57 PM
Originally Posted by ajk
Originally Posted by cncmotorsports
You hear these stories cause they don't cam them right, and people use crappy heads.
Don't be surprised with pro comp heads this motor is done making power at 6200-6300 rpm..
Are you implying that running a 383 over 7000 means it is not cammed right? if yes why? Just a question..What do you consider crappy heads?AFR,pro Comp,Dart?
It all depends, camshaft, cylinder head, intake manifold, carburetor and compression play a huge factor in where the engine will make peak power, and how long it will carry that peak power.
1 bad part in the balance of these components will make the engine suffer.
We build 383s for drag race and circle track designed to run 8000-8200 RPM.
Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad.
dragonmaster093 02-28-2010 06:07 PM
cnc dont see the balaning being an issue friend of mine built one for circle track lasted 3-4 seasons with nothing more then freahening bearings for his own peace of mind then when he rebuilt no major issues in side just went through it again for peace of mind so i dont know where your coming from
cncmotorsports 03-01-2010 05:52 AM
I am referring to the camshaft, heads, carburetor, intake manifold, these all need to be a good match to obtain great numbers.
I was not referring to the engine balancing it's Self.
dragonmaster093 03-01-2010 08:15 AM
[quote="cncmotorsports"]
Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad.[/quote
read your own post
cncmotorsports 03-01-2010 08:28 AM
I did...
What don't you understand ?
kikgas01 03-01-2010 09:32 AM
MAKE sure to check your crankshaft for cracks when using eagle. Jmo..
curtisreed 03-01-2010 09:35 AM
1 bad part in the COMBINATION of these components will make the engine suffer.
There, fixed it to save arguments.
cncmotorsports 03-01-2010 01:16 PM
I agree with you also.
