Isnt there a blocker plate on the block where a fuel pump would go on the TBI engine??
I didnt realize the differnces between the two. It was late at night when I replied and I wasnt thinking clearly. LOL |
Put a sump kit in the tank and put an electric fuel pump mounted under the car.
IF ITS GOING TO BE JUST A STREET CAR THIS WILL WORK, PUTS OUT SAME AS STOCK MECH PUMP, NO SUMP REQUIRED JUST PUT IT IN THE FUEL LINE. IVE USED THESE IN PLACE OF STOCK FUEL PUMP WHEN CAM LOBE TO DRIVE PUMP HAS WORN OUT. http://www.summitracing.com/parts/ACF-EP90/
I am confused. Do you want to use the block that has provisions for a mechanical pump or do you want to use the block without mechanical pump?
just trying to deside wich way to go and if i went with my 350 and new holley mech pump if i can just splice in to fuel line (since in tank pump not working) or if i have to do a bunch of other mods to fuel system or do i get a block off plate and run the electric pump and get a regulator or just put tbi 305 that came with the car ( a used replacement) and run it. its a mostly street car maybe few fun runs next year at street fights here in bristol
can pump be removed and piece of line put in its place
anything can be done.....WERE HOT RODDERS! :lol: dont think trying to pull through a dead pump would work.
| All times are GMT -8. The time now is 04:36 PM. |
