-   -   gas dumping out the front venturi (https://www.racingjunk.com/forums/showthread.php?t=28817)
rs72z 09-30-2010 11:54 AM
Re: leaky carb
Originally Posted by chevyart
thanks guys for sall the input. basically what you are all saying is to rebuild the carb and i am going to do that. i will soak that thing till the metering blocks fall off on their own(i hope), and i will definitely check the floats to make sure they still float.. i did get squirted by the carb, taking it apart(one of the guys said to wear safety glasses when working on the old carb) and he was right. i got stupid and got wet. still waiting to get a look at old power valve. i really think that was the problem . art
Check the oring on the needle and seat if they get hard it will allow gas out the boosters due to fuel level being to high. Like someone else said the powervalve will not let fuel dump out the boosters.
