-   -   Holley Squirter Check Vales sticking, Alcohol (https://www.racingjunk.com/forums/showthread.php?t=33875)
jmarksdragster 06-11-2014 11:40 AM
You might try a stainless check ball the same diameter as the check valve, and cut the same diameter as the ball off the length of the check valve. Put the check ball in first, put the old valve on top for weight. Don't ditch the body, if there is an issue with the seat that can be replaced as well. You can get them from BLP or Quick Fuel, those bodies are the same that Quick Fuel uses.
oneowner73 07-20-2014 10:53 AM
thanks for the reply Mark. Sorry it took me so long to respond. Good info that I will try. Will keep working with this main body but i think I could use a little more cfm and was looking at some of BLP's main bodies. Thanks again, Brian
oneowner73 08-11-2014 03:18 PM
Mark, I went through my junk and found 1 check ball the right size at .156. Had others too big and too small at .187 and .123. Where would I have to look to find another .156 check ball? Brian
curtisreed 08-12-2014 03:13 AM
You can get them from McMaster-Carr online. Or if you have a bearing sales place close by they usually have them.
Curtis
oneowner73 08-15-2014 04:14 PM
Thank You Curtis. I will give them a try. Brian
oneowner73 08-15-2014 05:19 PM
Check balls ordered. Had to order a quantity of 100 so I will have several lifetimes of this item. Was going to go to carb shops in Indy but buying 100 was cheaper than the gas. Thanks again and I will need that company in the future. Brian
oneowner73 03-16-2015 05:42 PM
jmarksdragster, do you have any time to work on a carb for me?
curtisreed 03-17-2015 07:30 AM
I don't know how often he comes over here since the change and drop off of users. You might be better off going to the site that is in his signature and asking him there.
Curtis
oneowner73 03-17-2015 04:21 PM
Thanks for the info Curtis.
Brian
