I ditto Tod,too.No sense in starting a motor until AFTER you set the valves
With all the issues he's been having, I wonder if he's in fact getting hyd. lifters. Solid, or Rhodes type maybe? :?:
there lunati hyd. and you have to set big blocks on 0 valve lash.and my rocker arms and nuts were bad.
Glad you got it figured out. :) |
hey lively I,ve got muffler bearings on sale this week at my muffler shop HA-HA :lol: :lol:
Yes but the 3" are a better buy!! :lol: :lol:
Lively , I only take american dollars, not ching ,ying pacos, oops-- better stop, starting to sound like Bob Frey. Of course it don't take to much to get a redneck going!!!
But good luck with that! |
This has been a very .....interesting thread.
stinky
heard detonation is a bad thing? man, this thread has been a stinker..
remember,this is a big block.you cannot turn them a quarter or half round like a small block.the motor will detonate!!
no,i'm not trolling.i think it's the other way around....no offence And i had great luck with setting the valve lash on 0.
for any hydrolic lifter to function properly they need .040 preload on plunger. that is where 1/2 to 3/4 turn comes in to play.
if it's stock it will work.or on a small block.just ask a big block company.or ect.like brodix,or dart(there also small block)or some big machine shops.on a big block the lifters build up more when you rev them up,so if there 1/4 or 1/2 turn it will be like 1 1/2 or something when racing.also roller rockers and poly locks or hex locks are important.
seized yes springs inside froze and quit oiling kindof like if the were solids,and new ones work good but now are starting to do it too the motor starts popping not loud popping like times too high and laboring almost dieing.can't set past .004 with feeler gauge hydrolic cam 490 like stock cam all stock lobes rockers and springs look good .maybe cams qround wrong :?: can't figure it out.help any?thanks
:shock:
i have a 454 and all my lifters stuck,so i put new ones in and ran one race and there already weak.when you ajust them the motor bogs down before the rockers stop rattling but.any ideas?thanks
i pulled out cam and lifters and 9 of the new lifters were froze like the old ones.all the new lifters worked good at first.it was in time the cam lobes were all good but about five were alittle bigger or smaller.i'm talking like a couple sheets of paper may supposed to be??i don't know!!
the first set didn't oil the second set did at first and started quitting 2
i have a prob. with frozen lifters.i'm not sure if these froze but the last two sets have.i went to practice tonight and it blowed out the oil stick,which happened last year and i kept racing so it burt a hole in the piston last year,and the rocker ams arm a little loose[same problem as last post]everything is new in motor.it also kills plugs.i think somthing is wrong in the heads,anyone have a idea.thanks
um,??problem?the cam,rockers and nuts were bad and the rockers were kicking sideways which made the push rods freeze the lifters(aslo bad dist.).runs great so far.thanks for help
Bet your parts supplier LOVES you.$$$$$$$$$$$$$ 8)
all i bought new was the cam and lifters(on this subject),but that was enough.got the rest from racing shops,and ect.always good to have friends
Speechless
Amazing :shock:
I say the control arm bushings are probably what caused all this....if you are gona run a Ratt you have to have big block control arm bushings.
RE; bad cam
Yep....And you*ll need a billingham-langston ganglia wrench in order to install those new bushings! Don*t forget the philpott extension, and those bushings, will need to be milled .025 over-all more than any other place.
then you have to magnaflux the whole deal.
AND WE ALLLLLLLLLLLL NEED A SHRINK!!!!!!!!!! :lol: :lol: :lol:
bad cam
if you have the cam out--check to see if one of the bushings isn't lined up with the oil passage in the block---or something in the passage could be restricting the flow--it has happened on a freshly hot tanked block --it just wasn't flushed out real good
Doesn't matter, B/BLK,S/BLK the lifters are the same size, there's .100 travel in the piston on the lifters. The only difference is if you have 3/8" studs or 7/16" studs. 3/8 1 turn equels .050, 7/16X20 equels 1 1/4 turns. Set it in the middle and go from there. But it really sounds like you have an oiling problem.
JMO Zip. |
Can't belive I just read all them posts. I would like to add some info but this thread is far two technical for me.
A hydraulic lifter whether in small or big block chevy adjusts the same. zero plus ½ to 1 turn. Anywhere close will work but may not perform as it could. Now I think the pushrods are too long causing the plunger to bottom out siezing the springs. :lol: |
THAT IS VERY TRUE 8) 8) --ESPECILLY THE LEFT HANDED ONE!!
This thread needs to be deleted, its not helping anybody at this point. this person was asking for help and obviously needs help. It is the object of this forum to help indivuials that are in need wether they know what they are talking about or not.
JMO Charles |
Thats the amusing part, he was getting good advise but just ignoring all of it, why ask for advice if your going to ignore it. :roll:
There is plenty of room for humoring and joking around in " In the pits" section of this forum without offending anyone's intelligence. Again JMO Charles |
I'm with Charles.Guy might not agree with us,but it's not our place to ridicule him.Starting to go too far now.Time to grow up.
| All times are GMT -8. The time now is 11:07 PM. |
