Re: D Drive
Originally Posted by bbchevy
Originally Posted by Dahlton
Originally Posted by zipper06
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. I was hoping it would be a killer and make over 1000hp... I will be using pretty Much the same set-up? 572"BBC,Jessel Belt Drive with a Cool Chrome/Moly Bracket for the 110 Enderle.The fellow i bought the Belt drive from,ran a Trigger,Crab Style MSD,and He also had a Pioneer Frt Drive set-up.But,the MSD Crab Style Dist with Crab Cap worked Fine with a HH/Retro Littlefeild 14/71. I will only be Using a 8/71,on the 572.But it will be ON CORN SQUEEZINS,(E85) I will be using a set of Merlin 345 IRON Heads,8.2-1 Static,775-800-Roller on a 114.I would Hope you make all of a Grand in HP?Cause im Sh@@ting for 14 to 1500........?We'll See. Later G 8) Your engine will be all race right? I'm not sure but would not more static compression be better when running on e85? I was hoping to runn smaller cam so the valvetrain would have a easier life. when you have it dynoed please give results! Would be super to compare! you have more cui, smaller blower and larger cam. Will you use a bird? |
Re: D Drive
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. I was hoping it would be a killer and make over 1000hp... I will be using pretty Much the same set-up? 572"BBC,Jessel Belt Drive with a Cool Chrome/Moly Bracket for the 110 Enderle.The fellow i bought the Belt drive from,ran a Trigger,Crab Style MSD,and He also had a Pioneer Frt Drive set-up.But,the MSD Crab Style Dist with Crab Cap worked Fine with a HH/Retro Littlefeild 14/71. I will only be Using a 8/71,on the 572.But it will be ON CORN SQUEEZINS,(E85) I will be using a set of Merlin 345 IRON Heads,8.2-1 Static,775-800-Roller on a 114.I would Hope you make all of a Grand in HP?Cause im Sh@@ting for 14 to 1500........?We'll See. Later G 8) Your engine will be all race right? I'm not sure but would not more static compression be better when running on e85? I was hoping to runn smaller cam so the valvetrain would have a easier life. when you have it dynoed please give results! Would be super to compare! you have more cui, smaller blower and larger cam. Will you use a bird? As far as the Dyno?Unfortunately,thats Not in My Budget! I will be using a Hilborn 4-Port MAGNESIUM Bug(want the Nostalgia Look) I may end up with a Shorter cam?750-760 Range....? Actually the Dyno with be a E.T.Slip.Race Only 71---75 Chevy Vega.The Car weighed Less than 1900lbs with a BBC and a Glide,when it was out last.So it will be FUN to Hang-On tooooo! Later G 8) |
Re: D Drive
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. I was hoping it would be a killer and make over 1000hp... I will be using pretty Much the same set-up? 572"BBC,Jessel Belt Drive with a Cool Chrome/Moly Bracket for the 110 Enderle.The fellow i bought the Belt drive from,ran a Trigger,Crab Style MSD,and He also had a Pioneer Frt Drive set-up.But,the MSD Crab Style Dist with Crab Cap worked Fine with a HH/Retro Littlefeild 14/71. I will only be Using a 8/71,on the 572.But it will be ON CORN SQUEEZINS,(E85) I will be using a set of Merlin 345 IRON Heads,8.2-1 Static,775-800-Roller on a 114.I would Hope you make all of a Grand in HP?Cause im Sh@@ting for 14 to 1500........?We'll See. Later G 8) Your engine will be all race right? I'm not sure but would not more static compression be better when running on e85? I was hoping to runn smaller cam so the valvetrain would have a easier life. when you have it dynoed please give results! Would be super to compare! you have more cui, smaller blower and larger cam. Will you use a bird? As far as the Dyno?Unfortunately,thats Not in My Budget! I will be using a Hilborn 4-Port MAGNESIUM Bug(want the Nostalgia Look) I may end up with a Shorter cam?750-760 Range....? Actually the Dyno with be a E.T.Slip.Race Only 71---75 Chevy Vega.The Car weighed Less than 1900lbs with a BBC and a Glide,when it was out last.So it will be FUN to Hang-On tooooo! Later G 8) You Vega guys :roll: :roll: :D I ordered the cam to day a Jones cam... Will be interesting trying something different... Ehat do you guys think about the spex?? 269/[email protected]" .412"/.412" Lobe Lift 114 LSA |
Re: D Drive
Ehat do you guys think about the spex?? 269/[email protected]" .412"/.412" Lobe Lift 114 LSA I would run 1.8 rockers. JMO. Dave |
Stick
Dave,
I was thinking the Stick is a Bit short in the Lift? I ALWAYS liked the 722 Lunati Grind. Later G 8) |
Re: Stick
Dave,
I was thinking the Stick is a Bit short in the Lift? I ALWAYS liked the 722 Lunati Grind. Later G 8) ran that same lunati cam (722/722) in my 511...awesome cam !!!!...Tom (Topsportsman) has had luck with this same cam in the past years.. |
X3
The 722/722 lunati is one bada$$ cam, I know couple other racers at my track that run it with outstanding results. Me and Landon run that same grind in our 496's too. It's funny, theres are a couple guys with (540's) in pro we're giving a run for their money. They run alkay, have bigger cams and ported out BB2X's - we run 110 race gas and cast iron heads. :shock: Alot to be said about the right combo. JMO>Cp |
The Lunati .722 works well normally asperiated, but don't forget he's running blown, so he needs a little more lobe seperation for it to breathe good (Lunati 110*) his is 114*
I've got a similar .725/.725---271/275---108 lobe seperation for the 496" i'm building for a customer. Zip. |
thats correct Zip i didn't read back thru the post and see where the Blower was mentioned..i just went down the List of his initial post..and still missed the part about the blower..lol
definatley needs a 114 Lobe seperation. i ran this cam on all muscle. |
Yep have to force feed because I'm not rich.
Found out last week that I have to change pistons. I bought the un-assembled short block from a las vegas company and when I started to look closer on the pistons I found out that they were waaaay wrong! so I got PO:ed and have now ordered a custom set from BME that should fit better... So I may not be able to run this summer but we'll see |
Yep have to force feed because I'm not rich. jk. lol |
Originally Posted by kwkracing
Yep have to force feed because I'm not rich. jk. lol rich guys have barton Hemis and over 800cid natural aspirated engines :D |
| All times are GMT -8. The time now is 11:07 PM. |
