-   -   JE Piston Tech (https://www.racingjunk.com/forums/showthread.php?t=21645)
torana434 09-08-2008 04:45 PM
It will be used for drag racing and some very occasional "street" driving, I am thinking of fitting a Procharger system to it, was hoping to use 98-100 ron pump fuel
ARUSSELL 09-09-2008 10:10 AM
That piston deck is designed for a N/A engine and could be milled to a flat top but no dish cut in it. I would not recomend this piston for a boosted application.
torana434 09-09-2008 04:46 PM
Thanks for your help
geosvet 09-16-2008 09:45 PM
SBC Stroker Piston
ARussell,
I just hurt my 364 SBC. I am using TRW L2278 pistons. I have been told they are now obsolete and Federal Mogul/TRW/SpeedPro does not have a replacement.
Does JE make a forged piston for a 364 SBC 5.7 rods that weighs about 540 grams? I need one piston.
Thanks, Geo.
ARUSSELL 09-17-2008 06:12 AM
Geo,
I apoligize I dop not have an old FM book, is that a flat top piston?
geosvet 09-17-2008 10:32 AM
Info for TRW L2278 .030 Piston
ARussell,
I looked through my stuff and here's the info that I have.
The is a Forged Aluminum Piston for a 364 SBC 4.030 x 3.562
Comp Dist 1.52
Dome height .193
Comp Ratio 12.5 w/ 64cc heads
Effective Dome Volume 9.6 cc
Weight 575 grams with no rings and no pin
I hope this info helps.
Thanks again, Geo
geosvet 09-17-2008 10:35 AM
L2278 Pinton Info
ARussell,
One more piece of info. The piston has a 1/16, 1/16, 1/8 ring groove configuration with normal ring groove spacing
ARUSSELL 09-17-2008 11:53 AM
I am sorryt but all I have are flat top pistons that weigh 475g. Best of luck to you, obsolite parts are hard to find.
hammertime 10-08-2008 12:30 PM
Does JE make a SRP piston for a 4.6100 Bore, be 4.375 stroke, 6.385 rod. Making a 584 CI BBC
ARUSSELL 10-08-2008 02:10 PM
We only have a piston for the 6.535 rod, I am not sure there is a crakn that is 4.375 stroks that will clear a 6.385 rod. I have parts to fir an conventional open chamber head and a 18 deg big chief.
