Thank's! your help is highly valued.
Is there a good reason why to use a bird catcher why not go with the buzzard straight away?
Bird
Either will Work FINE!
If you have access to a Bird Use it,a Buzzard use it? You will see Very little Advantage of the Buzzard over the Bird? Its more of a Preference thing..........? Later G 8) |
Originally Posted by OneBadGMC
2-3/8 to 2-1/2" primaries, by 4.5 or 5" collector.
are there a weldup kit with 2.5" and 5" collector any brand? or maybe a bolt on pair? |
Dynatech 600-904801 is 2-3/8 to 2-1/2 weld up kit
Add the 83-912502P 2-1/2 to 5 collector or 83-912502C (with coating and bung) Dynotech 600-904900 is 2-1/2 weld up kit. Use same collectors Hope you have a bunch of loose change..... :D Dave |
Add the 83-912502P 2-1/2 to 5 collector or 83-912502C (with coating and bung) Dynotech 600-904900 is 2-1/2 weld up kit. Use same collectors Hope you have a bunch of loose change..... :D Dave I ordered the headers. How many off you guys run a jesel belt drive with a mechanical fuel pump on the camshaft? Kit like this http://www.rbssuperchargers.com/Stor...05&InfoID=3921 Or would it be better to have a belt drive on the pump and take the power from the crank? |
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. |
Originally Posted by zipper06
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. I was hoping it would be a killer and make over 1000hp... |
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. I was hoping it would be a killer and make over 1000hp... http://www.goodvibesracing.com/searc...butor%20drives I do have the Snapps in the frig. it's just 1 shot is plenty, didn't say i didn't like, it it's just stout. On the other and i don't see how your motor could not make a 1,000 HP. Zip. |
D Drive
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it. On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure. Zip. I was hoping it would be a killer and make over 1000hp... I will be using pretty Much the same set-up? 572"BBC,Jessel Belt Drive with a Cool Chrome/Moly Bracket for the 110 Enderle.The fellow i bought the Belt drive from,ran a Trigger,Crab Style MSD,and He also had a Pioneer Frt Drive set-up.But,the MSD Crab Style Dist with Crab Cap worked Fine with a HH/Retro Littlefeild 14/71. I will only be Using a 8/71,on the 572.But it will be ON CORN SQUEEZINS,(E85) I will be using a set of Merlin 345 IRON Heads,8.2-1 Static,775-800-Roller on a 114.I would Hope you make all of a Grand in HP?Cause im Sh@@ting for 14 to 1500........?We'll See. Later G 8) |
| All times are GMT -8. The time now is 01:15 PM. |
