It could run low 11's, maybe even 10's. Obviously a lot of factors will contribute to that though. 3890lb 69 Chevelle, 496, 9.7:1, mildly ported 781's, 240ish, .580 lift solid cam, Perf. RPM air gap, Quick fuel 850, 10 inch converter, 3.55 gears, drag radials theu 3 inch ex, all the way out the back, runs 11.20's at 122.
Frank |
Thanks Frank that gives me some hope! I'll be happy for a while with mid 11's .
Originally Posted by gungho
Yes I concur,but I was saying at best,with good weather and all dialed,but more like a mid twelve to start with.that would be just my guess,of course there are a lot of variables,I would go with the biggest cam the heads will allow if I were running a four speed.
Good to see there is harmony in the RJ crib again. I don't know anything about those heads, so I kept my mouth shut. Besides, I have "Corvette" heads... don't need anything else.
Sounds like in good fall air on a good track, it will go low 11's easily. Mid 90's and super humid, obviously is no good for good et's. 119mph, will turn into 122-123, maybe a bit faster with tuning. With that mph, you could hit a high 10 even, if you got the car to launch good.
For the record, we have built 2 496's this year, with those heads. Both sets were ported, one set a bit more than the other, but not what I would call radical porting. One was a hyd roller deal, made 700hp and 630tq on pump gas. The other was a solid roller deal, on pump gas, made 740hp and 650tq. Neither engine was set on kill. Frank |
i had a 72 chevelle 468 all steel with flat top pistons closed chamber heads, similer cam, 4.88`s pump gaS motor.... ran 11,2`s all day....7.3`s eigth mile.
Yep I'm happy with it . Very nice to drive on the street (good manners). I think it has a lot more in it with some good air. Thanks alot guys.
Going from a 26 tall tire to a 28 incher its gonna kill some ET so expect that.
You can compensate for that and pick some ET by Footbraking/stalling the car up as high as you can without pushing thru the lights. JMO>Cp |
| All times are GMT -8. The time now is 10:50 PM. |
