-   -   SLOW 1-2 SHIFT ON TH400 (https://www.racingjunk.com/forums/showthread.php?t=19372)
SST4530 01-31-2008 10:44 PM
TH250 and TH350 are almost identical units.
olds48 02-01-2008 06:17 AM
I've always been amazed at the durability of stock "junk".It really holds up alot better than the aftermarket would like you to think.
jmarksdragster 02-01-2008 08:46 PM
Originally Posted by olds48
I do run a filter,not a screen.Cheap generic filter at that.Never crossed my mind. Cepxx,I always figured a 2-speed would kill my 60'.Then one night I accidentally took off in second gear(manual v-body),60' was the same,et was the same,picked up 4 mph in the 1/8!!!Gets you thinkin'....
A PG will ALMOST always be faster than a 400 with the correct converter.
There are exceptions, but for most cases the PG will win out.
olds48 04-15-2008 05:17 PM
Well..finally found out what was causing the lazy shift.My pump was worn so bad that the rings couldn't seal.Low pressure.Actually broke one of them.Took out 1st and 3rd clutches,2nd looks like new :shock: Just goes to show that if you don't know what you're doing,take it to the tranny guy.You CANNOT beat a man at his own game. :D
