-   -   Compression (https://www.racingjunk.com/forums/showthread.php?t=22119)
zipper06 05-02-2009 05:29 PM
David,
looking at the difference in torque values between the last motor and this motor, you might benifit from a little tighter converter, maybe 5500 to 5800. I think i read somewhere you were running a 6200 stall.
Nice numbers though for sure.
hammertime 05-02-2009 06:47 PM
Originally Posted by BEAST477
You gotta be pleased with those numbers. 8) See ya at the track tomorrow.
see ya there :)
hammertime 05-02-2009 06:48 PM
Originally Posted by zipper06
David,
Hey Zip, thanks was a 6750-6800 stall now a 6500, I run my stuff on the loose side so its not very aggressive down low.
zipper06 05-02-2009 08:25 PM
David,
I guess you're right i'm just used to these heavy weights.The lightest thing i've sat in, in yrs. and that was 2750 lbs and those have all been sm/blks with not a ton of torque. The last time i put a 7" 6200 converter in my 3100lb car it slowed down 10mph and 1/2 second, so i scrapped the idea of ever doing that again.
hammertime 05-03-2009 03:17 AM
David,
This one is 1981 with me in it a few weeks ago, I've tried a tighter converter in it last year 6100-6200 stall and it didnt like it much.
I'll have some track results today I hope :D
hammertime 07-02-2009 03:47 PM
Update you guys on the long rod and compression
Dyno Results very good ... track results its worth slim to none et wise but have seen mph difference.
I was told the long rod would look good on the dyno, so far its been 7.52@179 mph
I've swapped headers and 4 different converters, msd digital 7 along with coil, back tires, shift points, launch points .. all has changed nothing.
zipper06 07-02-2009 08:13 PM
I think the long rod motor creates a little more torgue, but would not be as evident on a light car such as a dragster, SO a tighter converter just might show improvment on the ET. I know you like to run a loose converter to keep the violence down in the first 100 ft.. Heck i'd put a 5500/5800 in it to see if it changed, the compression is not going to help on the top end unless you're running 8500 rpm.
hammertime 07-03-2009 04:03 AM
Thanks for the reply zip .. tight converter is slow and more often then not in the dragster it will be. I tried 5400/5800/6200/6700 stalls already, 6200 fastest 6700 next fastest. 5400 by far the slowest.
zipper06 07-03-2009 02:57 PM
Well guess you got me on that one, since you've been there. I'm more used to the high winding sm/blks and lower geared rearends.
michael1 07-04-2009 09:04 PM
Hammertime, you seem to be on top of things with the horsepower and compression deal, so I would like to ask what you think. I ended up with 13.3-1 instead of 15-1 compression. I wanted to know about how much power difference do you think that is. It's a 632 with Dart Big Chiefs and two dominators. The cam is 284in-304ex @ .50 on a 114 LC. The pistons are shipping out on Monday so I can still change them if need be. Thanks
