-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   Dang it..%^&*&^%$@#@@ (https://www.racingjunk.com/forums/showthread.php?t=22137)
bjuice 12-01-2008 06:07 PM
Actually i did better then this..i wiped Anti-seize on the outside collector ( might want to take them off one day)...reason they were so tight is the collectors had been thermal coated making the OD a little larger then un-coated.
Grease would have worked pretty good going on,,,but not much help when you want them off after running them for a season. :shock:
