-   -   1.428 60' time with 9.65 et is my 60' time slow? (https://www.racingjunk.com/forums/showthread.php?t=25286)
bowler 06-27-2010 08:03 PM
60'
i talked to Bruce about my 4 link which was set at 43" out & 6 1/2" up he thought the i/c should be out a little more and the spred on the bars at the housing should be 10" so i adjusted it to 10" & the i/c is 50" out & 6" up. raced sat. 5 runs 60' were between 1.414-1.446 et were 6.135-6.218 (got hot in the afternoon) sun. i adjusted the rebound tight & loosen the compression 4 runs 60' were 1.389, 1.384, 1.400, 1.407 (these 60' were my best at Madras) et's were 6.104, 6.140, 6.124, 6.136. can't wait to run at woodburn, the car is very consistent (considering this track & heat) since i put the 434" motor in this year, one other thing i did check the stall while on the t/b it is 5000, thanks to all for your input Doug
