Originally Posted by OneBadGMC
Guys, lets get back to the symptoms.
He said at 34 degrees, there was no issue. At 36 degrees, a miss occurs. A broken spring, pushrod, rocker isn't going to cause a miss with a change of 2 degrees of timing. A broken part will cause an issue at all times, no matter the timing change. |
Originally Posted by JEFF69Z28
NO CRANK TRIGGER.
34* IT HAS JUST ALITTLE MISS.UNDER NO LOAD. 36* IT RUNS ROUGH FROM 3000 THRU 5000.UNDER NO LOAD. I GUESS WHAT IM ASKING IS COULD I HAVE BEEN OF A TOOTH OR SO OFF WHEN I PUT THE DIST.BACK IN AFTER I LOCKED IT OUT?I PUT IT BACK WHERE IT WAS OR I THOUGHT I DID.I WOULD LIKE TO TAKE IT OUT AND REINSTALL IT.TO DO SO WOULD I GET NUMBER 1 TO TDC(0) AND THE MOVE THE BALANCER TO 34* THEN DROP THE DIST BACK IN MAKING SURE THE ROTOR IS POINTING TO THE NUMBER ONE PISTON. |
The point being, a miss due to a broken piece of the valve train is typically going to be RPM dependent, and won't change with ignition timing.
without looking at the car, you, are myself are just giving best guess.
the video of it running you ask for would help. I'm thinking a crank trigger would solve the problem ,but that is me.JMO |
SHOULD I HAVE 2 BATERRIES ONE TO START THE CAR AND ONE FOR ACESSORS,RIGHT NOW I HAVE 1 BATTERY TO DO EVERYTHING,START CAR,RUN DUAL FANS,WATERPUMP AND IGNITION AND I HAVE A 100 AMP POWERMASTER ALTERNATOR CHARGING THE BATTERY.
TOOK OUT 6AL2 AND PUT 6AL BACK IN AND IT REVS ALOT CLEANER NOW,NEXT IM GOING TO CHECK THE ROTOR PHASE.
went to track car had a stumble on launch started messing with jets stumble started to go away 60' went from 1.52 to 1.47 then ran out of time.one thing i didnt understand was when my 60'dropped my mph also dropped why is that?
What did you change in the jeting to improve the 60 ft? Give some info about the carb.Bill.
| All times are GMT -8. The time now is 01:21 AM. |
