-   -   wont idle (https://www.racingjunk.com/forums/showthread.php?t=27341)
mopar1968 02-17-2010 05:33 AM
What was the compression reading on each cylinder :?: :?:
''JUST MY TWO CENT'S WORTH''
THERATTLER 02-17-2010 05:47 AM
I had an intake gasket blown between the port and lifter valley and had similar problems , idle problems and oil in cylinder , might give that a check...same engine backfired one time and blew one valve cover up like a football :lol:
bowhay 02-17-2010 09:43 AM
they were all about a 170 lbs
DirkaDirka 02-17-2010 10:12 AM
Does it have aluminum heads on it? Did it over heat at any time??
I had a 89 Probe that warped the head when it overheated one time and it wouldnt idle at all. Found out I burnt the rings in it and warped the head. There was no water in the oil or anything.
Tod74 02-17-2010 12:38 PM
Bowhay do you know anyone who could help you do a leak down test? That will give you a better picture of the condition of things.
bowhay 02-17-2010 05:55 PM
ok so i found the culprate
i pulled the heads and there was a puddle of oil standing on top of number 7 and 4 and a lil on almost all of the valves, so i pull the springs off and the guides are so bad tht almost all of the valves have play in them
and a few will actually jiggle from side to side,
THERATTLER 02-17-2010 06:03 PM
Originally Posted by maniac
if you are getting enough oil down valve stems to foul the plugs then the guides are worn out bad.,,as I stated earlier , i have run heads with NO seals at all with no problems ( good tight guides) just my input :)
:D :D :D :D :D :D :D :D :D
dragonmaster093 02-17-2010 06:15 PM
nice job manic
TheYellaBrick 02-17-2010 06:16 PM
5 pages to figger this out ????????? :shock: :shock: :shock: :roll: :roll:
lively 02-17-2010 06:27 PM
Originally Posted by dragonmaster093
nice job manic
MAN--NOW HE WILL HAVE A BIG HEAD AND WON'T SPEAK TO US SMALL PEOPLE :oops: :oops: :oops: :oops:
