-   -   wont idle (https://www.racingjunk.com/forums/showthread.php?t=27341)
THERATTLER 02-17-2010 06:34 PM
it already outgrew my hair
dragonmaster093 02-17-2010 06:36 PM
let me fix this mopar and others who said this nice job :lol: :lol:
kwkracing 02-17-2010 06:37 PM
most guides have a few thousands of play unless the heads are new or near new or have had the guides replaced. Find someone to help u go threw a entire engine.
bowhay 02-17-2010 06:47 PM
im going to go threw the whole thing
i know there should be some play but there is ALOT in a couple of these guides,
im takin the heads to the machine shop tommarrow to get new giudes installed and another valve job done
thanx so much to yall who helped me figure this thing out
THERATTLER 02-17-2010 06:52 PM
dont take it to the same one that did those heads
kwkracing 02-17-2010 06:53 PM
:shock: :shock: :shock: :shock: :shock:
bowhay 02-17-2010 07:07 PM
im not
Tod74 02-17-2010 08:49 PM
You said this engine had 1200 miles on it...and you say ANOTHER valve job,so I assume you had the valves ground when you built the engine...How did they not know the guides were bad ?Hard to imagine any competant machine shop doing a valve job on a set of heads with worn out guides.
cepx111 02-17-2010 10:07 PM
If you got oil puddled up on top of the pistons, you've got other things to worry about than a wiggle in the valve guides.
JMO>Cp
MEMRACING62 02-18-2010 04:29 AM
JMO>Cp
thats for sure!!
