-   -   b1 heads,indy block oiling issue (https://www.racingjunk.com/forums/showthread.php?t=1289852)
ArmDropDart 03-28-2016 06:37 PM
I have a set of original b1 heads with t&d rockers on a indy maxx aluminum block. it has the drain lines from the heads to the pan and on the stand at 2-3k rpm its starts to run out of oil. the indy block holds more in the valley area and with the lines I put extra oil in it and it still is going dry. any suggestion or info would be greatly appreciated. THANKS
