-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   Nova LS swap (https://www.racingjunk.com/forums/showthread.php?t=1289876)
Swiley383 05-01-2016 06:40 PM
Nova LS swap
Thinking about doing a LS swap on my 74 nova bracket car. It a stock suspension bracket around 3200 lbs. wondering if the pay off would be worth the effort. Would most likely be a 5.3 or a 6.0 LS. What is the max lift cam the stock heads can handle? Not sure if I will go the carb or EFI route. What do you guys think?
lugnut 07-31-2016 01:24 AM
I cant believe nobody responded to this in 2 months Absolutely,LS all the way NOthing worng with gen 1 SB but once you get used to LS,its a different animal I have one in my 70 chevelle,carb I would go 6.0 if its in budget,more cubes ,why not With ls6 springs you can do a hot cam with ease,Carb is much simplier than EFI for the first timer
Swiley383 08-02-2016 05:50 PM
Still not sure what I am going to. Most likely will leave my mild big block in for a while. Just don't have the time right now. Set this motor in a while back and still haven't had time to finish it. Nothing is hooked up yet.
