-   -   PRW Shaft Mounted Rockers (https://www.racingjunk.com/forums/showthread.php?t=1289907)
hardatach01 06-18-2016 07:25 AM
Does anyone out there have any experience with PRW shaft mounted rockers?
Thanks in advance,
Ben
curtisreed 06-20-2016 03:34 AM
Those are an import item. For less than $100 more ( SBC is what I compared ) you can get LGM rockers made in America.
http://lgmrnd.com/index.php/header1/...ock-chevrolet/
Curtis
hardatach01 06-23-2016 08:00 AM
Just wondering....cuz I have a chance to buy a set of 1.5's for 80 bucks. The set has one bad rocker, but I checked with PRW and you can't just buy one rocker and put it on the broken one. The set (1 pair is 46 bucks) so I guess I have a set of shaft mount rockers for 126 bucks. I think that a pretty good deal and I'm not going to turn the motor over 6800. The web site says the rockers will take up to 750# of spring pressure, but I'm going to run a hydraulic roller that only needs 450# of open pressure. Hope it works (fingers crossed). I'll keep y'all informed.
curtisreed 06-23-2016 09:53 AM
Sounds like it would be to bad of a deal to try for you. I would go for it.
Curtis
