-   -   My Nissan Project... (https://www.racingjunk.com/forums/showthread.php?t=1289968)
mytmouz 08-27-2016 09:57 PM
I thought I would (try) to post some of my rides here. Photobucket is being difficult right now...
Anyways, I have a 1989 Nissan D21 Hardbody I inherited from my grand father. The truck has always been a PITA to me, but I will keep it as long as I am around. The truck was a basic truck, only options were AC, power steering and an automatic trans. IT was originally grey with steel wheels. It had no tinted glass, including the strip at the top of the windshield, and the rear view mirror did not have the night view option (it did not have the tilt feature you have by sliding the switch mechanism). A couple of deer over the years and one accident due to the other driver running a red light has made replacing most of the sheet metal necessary, and it has a later model front end on it, and a color change...
http://i105.photobucket.com/albums/m...ruck/003-5.jpg
mytmouz 08-27-2016 09:59 PM
I rebuilt the engine after it gave up one night, and about 800 miles prior to the first oil change, the trans let go. You have to pull the motor to remove the trans, so...
http://i105.photobucket.com/albums/m...o/100_0038.jpg
I installed a 5.7 vortec, with a GMPP swap intake. I installed a tbi system that way (I did not have to swap out the factory fuel pump with the tbi). ANd I used a 700r4 trans, did the wiring harness myself using the donor tbi harness...
http://i105.photobucket.com/albums/m...ps7fdeb7e9.jpg
mytmouz 08-27-2016 10:04 PM
I installed the drivetrain using stock GM senders for the computer. I used the stock Nissan senders I adapted to the engine to run the factory gauges. I scored a set of Nissan Pathfinder bucket seats in the correct color and a 2002 Chevy Blazer console for the floor shifting action. Truck looks totally stock inside. (no good pics, I am famous for taking crappy pics)...
mytmouz 08-27-2016 10:07 PM
I have also upgraded the rear with a Ford Exploder 8.8 with 31 spline axles, a posi, and 3:73 gears and disc brakes, and the front I machined some Toyota truck rotors so I would have a matching 5 on 4.5 lug pattern. I have a 1983 Ford F150 stepside bed I plan to cut down to fit. So for now it is rolling on some ugly white spokes until I can get the final wheel width...
http://i105.photobucket.com/albums/m...psanbvu6rs.jpg
mytmouz 08-27-2016 10:08 PM
I drive it weekly as is. I plan on finishing it someday...
Harbone 08-28-2016 04:22 AM
I bet that thing will haul azz!
mytmouz 08-25-2018 07:00 PM
And here is a really crappy pic of the truck now. Since my other 2 mini trucks have big cowl hoods, and are step side trucks, this one had to be as well... I modified a 1983 Ford thoroughbred bed to fit,using the Nissan metal bed floor, and also added the new wheel and tire combo.
http://i.imgur.com/B6e2rNyl.jpg
Swiley383 09-03-2018 05:41 PM
You have been busy
sisatmp 08-10-2026 12:15 AM
Anyways, I have a 1989 Nissan D21 Hardbody I inherited from my grand father. The truck has always been a PITA to me, but I will keep it as long as I am around. The truck was a basic truck, only options were AC, power steering and an automatic trans. IT was originally grey with steel wheels. It had no tinted glass, including the strip at the top of the windshield, and the rear view mirror did not have the night view option (it did not have the tilt feature you have by sliding the switch mechanism). You should definitely check out their selection of live games if you're feeling bored with the yesplay register online login usual sports markets, as they really offer a different level of excitement that’s hard to find elsewhere. A couple of deer over the years and one accident due to the other driver running a red light has made replacing most of the sheet metal necessary, and it has a later model front end on it, and a color change...
That Nissan Hardbody sounds like a survivor. It's funny how we end up keeping vehicles that were a total pain just because of the family connection. Swapping the front end and changing the color definitely gives it a custom vibe, even if it started as a basic model. Hopefully you can get your photos sorted out soon, as everyone here would love to see the progress on that build.
