-   -   Best Trans for Street for BBC 496 410's Rear (https://www.racingjunk.com/forums/showthread.php?t=1290069)
sbc421truck 01-04-2017 11:50 AM
Any recommendations for a full Manuel Automatic
Th-350/Th400?
10:1 BBC 496
580 HP 610 TQ
255-260@50 solid roller
410 rear.
In 3700 LB C10 Blazer.
Keeps breaking cases from Hughes and TCI-stock cases.
Swiley383 02-05-2017 08:53 AM
Is everything correctly lined up? Breaking cases would make me suspect to something not being correctly in line.
stevesolo16 12-10-2018 06:15 PM
Was the company you purchased the tranny from installing new cases or just welding the broken one?
Swiley383 is correct referring to misalignment or a bent component. I had a case with a misalignment and
it cracked the outer case. No matter what I did I couldn't make it work to my liking and finally replaced the case.
As far as what trans is correct for you? In a 3700 pound car, with 580hp I most definitely stick to a 3 speed.
A TH400 is built for heavier cars. If you decide to up the HP the TH400 can handle everything you can throw
at it. There are some good high-performance transmission shops out there and building a TH400 to handle 2500hp+
isn't unheard of. Good luck!
