-   -   Motor Oil (https://www.racingjunk.com/forums/showthread.php?t=1290219)
stevieray55 08-13-2017 06:07 PM
Motor Oil
How do you know what motor oil to use? What's a good oil to run in my 331 stroker that I'm going to run 1/8 mile? Shifting at 6300 should oil pressure be 60 - 70 at shift or higher?
Swiley383 08-14-2017 05:45 PM
I would run a synthetic oil. Make sure it's a high zinc oil if you are using a flat tapped cam. If you do use a conventional oil I have had good results with Valvoline VR1.
