-   -   Brakes on my gbody (https://www.racingjunk.com/forums/showthread.php?t=1290305)
bad1980malibu 01-03-2018 03:44 PM
Brakes on my gbody
I change my Malibu to manual brake bought the kit from trz. I have nine inch rear with disc brakes. Is there anything else I have to do to make it work. Thanks
Harbone 01-03-2018 03:52 PM
What all is included in the kit?
bad1980malibu 01-03-2018 04:02 PM
The master cylinder and plate for fire wall and the linkage rod for the brake petal. The rear is a spraker racing nine inch with gm calibers the brake petal feels good. But when I drive it it don’t stop like I want
Harbone 01-03-2018 05:12 PM
Are you still using a stock proportion valve?
Swiley383 01-04-2018 03:15 PM
Also check your lines. The rubber lines going from the steel line to the calipers can collapse inside.
bad1980malibu 01-04-2018 03:54 PM
I put new rubber line on front. I am still running the stock proportion valve.
Harbone 01-04-2018 05:44 PM
Get a adjustable proportion valve, the stock valve is not set up properly for a front and rear disc manual brake setup. its probably not sending enough pressure to the rear calipers.
have you done any hard braking to see what wheels lock up first?
