80 malibu help
i have a 80 malibu roller i bought already has a ford 9in im planning to put a 598 with a 400 trans with a trans brake an nos wanted to know what can i do to make the rear of the car hook and launch without tubbing it and how big i can go with the tires. i also did front end with upper and lower tubular arms and front coil overs any ideas or help thx
Originally Posted by dragracerx
(Post 1530630)
i need that too
Cutting cost would be doing as much as possible without a mechanic. Labor hours will be painful, so try to do as much as you can on your own. When I got my first project car I made it a priority to first get it back to running and driving perfectly. That meant changing all the fluids, fixing any leaks, tuning the carburetor, changing spark plug wiring, bleeding brakes, repacking bearings, suspension, get a proper alignment, new tires. When you get it going nicely, then refine it and improve it. Good luck. Nice ride you got there.
Kosten sparst du am besten, wenn du möglichst viel selbst machst statt zur Werkstatt zu gehen – Arbeitsstunden sind teuer. Bei meinem ersten Projektauto habe ich es goldspin-de.com zuerst zuverlässig fahrbereit gemacht: alle Flüssigkeiten gewechselt, Lecks behoben, Vergaser eingestellt, Zündkabel erneuert, Bremsen entlüftet, Lager gefettet, Fahrwerk geprüft, Spur eingestellt und neue Reifen montiert. Wenn alles sauber läuft, kannst du es Schritt für Schritt verbess
| All times are GMT -8. The time now is 12:56 PM. |
