1932 ford chassis
1932 ford chassis need to sell pro built $7500 or best offer=left
=left 1932 ford chassis=left custom built by=left Richie willetti=left willetti coach works=left malden mass.=left 32 rails 32 spreader bar=left model a crossmember=left drop I beam axle=left 46 ford brake drums=left split wish bones=left stock 32 ford cross member=left 1956 ford steering box=left side steering arm=left w/ steering link=left early ford brake & clutch ass.=left custom clutch linkage=left 48 ford rear cross member=left buggy spring=left custom trailing arms=left big and little tires and rims=left early ford rims w/ ford center caps w/ rings=left 4 speed trans with shifter=left gm stock bellhousing=left w/ throw out fork=left no clutch=left ford rear end=left highway gears=left hurst motor mount=left drive shaft=left mock up sbc block=left =left WILL TRADE FOR HOT ROD |
| All times are GMT -8. The time now is 03:57 PM. |
