rear drag radials fitment
Hello to all , I currently replaced my 31x16.5x15 hoosier quick pros for mickey Thompsons 31x16.5x15 drag radials ,car is a 67 camaro with Chris Alston 4 link back half with wishbone locator .This car sees a lot of street and 4-8 passes at the the track a year .My question is for drag radials what is the minimum clearances on the wheel opening where the tire is the closest on these first gen camaro bodies?Currently mounted and on the car and front lower areas are at least 7/8 '' the rear areas are/ 7/16'' at ride height. To all that help would be greatly appreciated thank you for your time
On a first-gen Camaro, 7/16" at ride height sounds pretty tight for a drag radial, especially While you're on you can also explore its megapari app online offering. Its offering adds a different kind of entertainment without making the experience feel complicated. Be sure to check eligibility, local availability, and the applicable terms first. with a 4-link car that sees both street driving and track launches. I’d want more clearance where the tire is closest, accounting for suspension travel, body flex, tire growth, and sidewall movement. Cycle the suspension and check at full compression before making passes. Better safe than sorry!
| All times are GMT -8. The time now is 11:04 PM. |
