Crank change?
I have a 2001 LQ4 out of my Silverado, I need to change the crankshaft due to hydralock and the reluctor ring getting messed up. I was going to swap this into my S10 Blazer, using carburetor and MSD box. So because I was buying a box and I wanted the 58 teeth ring. I since have changed my mind and going 406..
My question is will the cam that in the engine (the one that worked with the 24 teeth ring) work with the 58 tooth reluctor ring? |
| All times are GMT -8. The time now is 03:59 AM. |
