Small block Mopar thrust bearing problem
I haven’t ever seen this before, but the crank looks to be pushed forward from the torque converter and is wearing down the thrust bearing. This is a cast crank 340; there is about a 1/8 to 3/16 gap unbolted between flex plate and converter. Spins freely, and moves back and forth easily. The forged crank 340 has no problem with same Trans and converter. Any ideas?? Thanks
| All times are GMT -8. The time now is 07:23 PM. |
