12v to 16v
Hi All
I believe this been discuss before converting to 16v and know I will need a 16v battery and charger. Just can't find the original discussion now. Will I need to change current alternator to a 16v alternator? And what about the water pump and fans. I'm thinking this should be OK and the 16V will run them faster. Is this correct? Thanks |
When converting to a 16V system, the alternator situation is usually the key point people miss. In most cases you’ll need a proper 16V alternator or a regulator setup designed for 16V charging, because a standard 12V alternator won’t charge the system correctly or may overwork itself trying. As for accessories like water pump and fans, most 12V units will run faster on 16V, but that’s not always a good thing—they https://rocketspin-au.com can overheat, wear out quicker, or move air less efficiently outside their design range. It’s generally safer to run dedicated 16V-rated components or use voltage reducers where needed. The system needs to be planned as a whole rather than just “upgrading voltage.
Oui, si tu passes à un système 16V, tu devras effectivement remplacer ton alternateur actuel par un alternateur compatible 16V. Cela garantit que la tension de charge est adéquate pour le nouveau système. En ce qui concerne la pompe à eau et les ventilateurs, le passage à 16V pourrait ile de casino les faire tourner plus vite, mais cela pourrait aussi entraîner une usure plus rapide si ces composants ne sont pas conçus pour supporter cette tension. Assure-toi que tous les accessoires et composants électriques sont compatibles avec 16V pour éviter d'endommager ton système.
| All times are GMT -8. The time now is 06:41 PM. |
