-   -   converter ? (https://www.racingjunk.com/forums/showthread.php?t=17117)
nabit 12-24-2006 06:25 PM
converter ?
I am looking at buying a new converter from a guy that states it is a vega converter that was cut open rebuilt,cleaned up and set for 3700stall and it is a 10inch 350 converter. My question is I can't find any info on a vega converter, company or anything. Is it a chevrolet vega stock converter that was rebuilt and changed or is there and actual company called vega converter?
Thanks!!
lookingaround 12-24-2006 07:08 PM
if its a stock vega stahl it want take a whole lot of power it will come apart..and if it is a vega convertor you will have to drill your flywheel to get it to bolt up. thats the problems i have run into with them..good for a street vert but not race..JMO
nabit 12-25-2006 02:28 AM
thanks, I will pass on it..
lookingaround 12-25-2006 05:30 AM
if oldani would come in he could tell ya for sure he is the tranny guru
nabit 12-25-2006 12:05 PM
Nice bike!!! I use to have an 01 gixxer 1000, damn do I miss it....
3758 01-26-2007 07:55 PM
vega convertor
Know body can tell you what a convertor stalls at unless the know what torque your motor puts out. buy a convertor from a manufacture who will set it up for your application a 5000 stall in my car might stall 3500 in yours
Oldani 01-27-2007 06:01 AM
As a very general rule of thumb, each 50 hp move will change stall speed roughly 200 rpm. I'd advise you to use a decent converter. At least one with furnace-brazed fins and possibly anti-balooning plates. It's easier to spend your dollars once than twice!
mcracecars 01-27-2007 02:50 PM
Have to agree with OLDani, Im afraid. One thing I have learned over the years is to never buy a used converter unless you know the guy real well and the car it came out of.
Nothing will pi** you off more than buying a "good used converter", going through all the work to install it, driving 2 hours to the track, and finding out the converter is junk....
Buy one from a known manufacturer. Call several and ask them for their recomendation for your vehicle.
chris301y 02-01-2007 02:36 PM
call Greg Slack.
refill 05-05-2007 03:41 PM
need a number for greg slack
Originally Posted by chris301y
call Greg Slack.
