don't buy gas on 5/15/07
Mite have been posted before. But in case you have not seen it. I'll pass it on.
"Don't buy gas on the 15th if one fourth of the country doesn't buy gas for 24 hours the gas companies lose 2 billion dollars and it will lower prices... Its called the F-U gas company day.. And it will lower the gas prices" |
buy it on the 14th or 16th instead. The only way you will hit the oil co. is to stop using as much gas as we do. Not buying it on one certain day will do nothing.
http://www.snopes.com/politics/gasoline/nogas.asp |
http://forums.racingjunk.com/viewtopic.php?t=2758
I agree, picking a day to protest will do nothing, driving something that's better on gas will do something. |
I was told that the reason is they will drop the price in the next day or so to make up for the loss. So we can save a buck or two and stick it to the man,lol. Now mind you this is not my idea, nore do i know if it will work. I was just told it happened in 97 or 99 and worked. And beside what can it hurt to try it?
i agree what would it hurt to try it
GAS SAVER
CHEAP ON GAS AND I DON'T THINK DYNOFLO CAN MESS THIS ONE UP
http://www.racingjunk.com/post/88068...LD-BE-4hp.html I WOULD PUT THE PIC ON BUT ????????[/img] |
I agree, picking a day to protest will do nothing, driving something that's better on gas will do something. :shock: :wink: |
Re: GAS SAVER
http://www.racingjunk.com/post/88068...LD-BE-4hp.html I WOULD PUT THE PIC ON BUT ????????[/img] LOL....they would mess it up, someone would forget to put the bolt that ties the horses to the coach, or it would just barely be in and cause an accident |
Scot would put the Shoe,s on Backwards
if i run out of gas on the 15th i will be pissed and have to walk lol. i get about 4-5 miles to gallon i guess i should find something a little better on gas lol.
| All times are GMT -8. The time now is 08:14 PM. |
