-   -   drag wheels/tire question (https://www.racingjunk.com/forums/showthread.php?t=17201)
jaykz1000 05-08-2007 07:17 PM
whats the pros and cons in puttin 10.5 slicks on 12 inch wide wheels???
slowman 05-08-2007 07:27 PM
you don't put a 10.5 on a 12" rim. the 10.5w will go on a 12" rim it helps the foot print of the tire on the ground. alot of 10.5 outlaw racers run them like that but the tire needs to be aleast 30" tall or taller to do it. i never had good luck with doing it with a 28" tall tire.
edvancedengines 05-19-2007 02:35 AM
Not meaning to argue, and I won't.
True 10.5 racers with tons of Horsepower are mostly using the 13-14- & even 15 inch wheel to mount their 10.50 tires on. That does require using Beadlocks to get the tire stretched out to the wheel. That is one reason why a True 10.5 tire looks so big. Also usually their tire of choice is the M/T. I am talking about 1 1/2 inches of rubber on the ground with engines of 1,700 to 2,000 hp. and they do hook.
However the normal accepted rule of thumb is the tire and wheel need to be within two inches of each other.
Way back when, I ran a 13 inch wide wheel with a 15 inch slick that was 33 1.2 tall. Can you say footprint and tire growth on the big end. lol.
I also ran a ten inch slick on a 7 inch wheel in a 11 second Chevelle. Low air pressure with that one was a scarely driving experience.
Ed
slowman 05-19-2007 09:41 AM
ed no argue here i agree with every thing you said. the guys that are doing the 10.5 on that big of rim are seasoned racers that know the does and don't of it. i was thinking saftey first.
jaykz1000 05-20-2007 06:01 PM
well i have seen it done with W tires on say 14 incvh wheels... i figured a true 10.5 with tubes and screws qill go on a 12 inch wide wheel what u guys think ?
bryanm 05-26-2007 01:57 PM
If you havent already gotten wheels I would get 10 inch wheels, I have run 10 inch wide tires on as small as an 8 inch rim, I have never really heard of too many people trying to put smaller tires on big wheels though.
