-   -   powerglide stuff (https://www.racingjunk.com/forums/showthread.php?t=17365)
mikeaton 05-23-2007 03:10 PM
powerglide stuff
hey guys got a delima i ordered the imput shaft for a 1.76 and they sent me the box for a 1.76 my shaft is 12 5/8 as the 1.76 is but they sent me a 12 7/8 long can i use it? also where does the "wedding band go? man im really in a pickle here any help? thanks mike
sp2816 05-23-2007 03:18 PM
The 1.76 input shaft is supposed to be 12 7/8" and the 1.82 input shaft is 12 5/8". So, it sounds like they sent you the correct one for the 1.76. If you truly need the 12 5/8" long shaft, you can not use the 12 7/8" as the torque convertor would not be able to slide on far enough. The gold wedding band fits inside the small slinger/shield that rests against the hub inside the high gear drum.
Bill M
bjuice 05-23-2007 03:35 PM
what kind of input shaft did you Buy Mike stock or aftermarket..such as a vasco etc...????
i will tell ya somehting Bill m is on the stick..this fella knows his parts..i am inpressed BILL...ROCK ON !!!!! 8) 8) ..
hes correct on where the band goes..........
later Brian
sp2816 05-23-2007 08:22 PM
Thanks, Brian. It also helps that this past weekend I was freshening up a glide. The JW Powerglide Transmission book is a pretty good handbook that I use.
When I started racing over 20 years ago, I had the money for the parts or the labor. I bought lots of books and learned how to work on it, so that I could have money for more parts. So, I learned a lot of the ways to not do things. One of the most fun was finding out that there are over 100 needle bearings in the countershaft of a Muncie 4-speed held in by wheel bearing grease.
Bill M
mikeaton 05-24-2007 05:19 AM
powerglide
as usuall you guys are here for us racers thanks again bill brian we bought a tci shaft[which im going to send back and get the right one ] from jegs also carp from a-1 transmissions here in artesia gave us a great deal on some clutches and steels so ill be ok there everything else looks great just my mistake will cost us a weekend of racing! maybe it will rain this weekend! well bill thanks again and thanks for checking in brian you guys rock!!! mike in new mexico
3dracing 05-24-2007 07:55 AM
BTE's shafts are universal, no need for a 1.82 or 1.76.
Steve
mikeaton 05-25-2007 05:56 AM
trans
thanks steve ill look into the bte stuff ive got to send this one back so ill check with jeggs on that thanks guys mike
