-   -   LOOKING FOR ADVICE (TURBOCHARGERS) (https://www.racingjunk.com/forums/showthread.php?t=17392)
SLEEPER420 05-26-2007 06:22 AM
I AM LOOKING FOR ADVICE FOR A PROJECT OF ME AND A FRIEDS
THE PLAN IS THIS --- 85 CHEVY MONTE CARLO SS//// 350 .030 OVER FORGED CRANK RODS AND PISTONS TUNED PORT INJECTION TWIN TURBO ROLLER CAM LIFTERS AND ROCKERS. LOOKING FOR ADVICE ON WHAT SIZE TURBO. TYPE OF CAM AND STROKE OF CRANK TO USE THINKING OF A LITTLE OVER STOCK. THANKS FOR THE ADVICE.
billhendren 05-26-2007 08:28 AM
How much power do you want to make and is this race only or street/show car.
If its a race application a stock block will be very marginal as far as the main caps,I would look seriously at a Dart Little m at the very least if you intend on making any kind of power.Bill
SLEEPER420 05-26-2007 03:12 PM
ABOUT 450 HP AT THE WHEELS
ITS GOING TO BE BOTH SHOW/STREET AND RACE WILL BE USING A VARIABLE FUEL MANAGEMENT SYSTEM AS WELL FOR DAY TO DAY DRIVING
thetanman101 05-27-2007 02:14 AM
You can get 450 horses without the expense of turbos. Stroker crank and some more compression will get you there with a decent set of heads. If your set on turbos, then you've come to the right place for experience. I'm sure Brian will be along shortly to lend some insight.
-Tanner
Robert1320 05-29-2007 09:48 AM
www.theturboforums.com
If you only want a 450hp a little stroker would do it.
If you are set on a turbo a single MP 70 would make more than enough.
If you are looking for around 1k hp an S400 could gety you close.
I hope you have an early 010 casting block with steel center caps.
A short fill would not hurt. This with a good forged bottom end.
Use JGS WG and BOV and get some good siozed injectors.
I would check out the www.theturboforums.com for more info.
